Unusual potentiometer
ccurtis
Can someone explain the potentiometer, R55, in the figure below. I only know about three terminal pots. It is ganged with an identical pot for the other audio channel and is the volume control for an OLD Grundig radio. I want to simulate the tone circuit but can't because I don't know the internal structure of a 5 terminal pot.
It's probably some version of a "Loudness" volume control - the commoner ones have a single fixed tap on the track as somewhere around 40% or so.
Some examples:
You should be able to simulate the effect using a fixed resistor divider to provide the taps, in parallel with a standard potentiometer for the volume output?
The effect is supposed to be to reduce bass (and sometimes treble) a bit less than midrange with the volume below a certain point, to compensate for hearing being more sensitive to midrange at low volumes.
As suggested, they are taps are for 'loudness' adjustment - but usually there's only one tap on the pot.
'rjenkinsgb' is unfortunately mistaken about simulating it using external fixed resistors, as it requires the slider of the pot to pickup filtered signals as it goes up and down, the external resistors don't provide this.
It's LONG been a problem in audio repairs, basically the two options are:
1) Source the correct potentiometer - usually impossible.
2) Ignore the tap(s) and don't bother with loudness compensation.
Bear in mind, most audio systems don't provide loudness compensation, they just use a plain pot - you can do the same, and you'll probably not even notice any difference.
You should also bear in mind that for top end HiFi it's a definite 'no no', as you're modifying (distorting) the original signal.
Having done repairs professionally for 40 years, in the many cases where the pots weren't available we simply fitted a normal pot - and didn't even bother telling the customer. Not a single one ever came back and complained it sounded any different :D
Thanks, guys. That very helpful information! I had NO idea.
So, Nigel, would you have soldered the wires that went to the two taps, each connected to the nearest respective endpoints of the 3-terminal pot? Or just leave the tap connections disconnected? Or a combination of those two, depending on which tap? On this radio, the thing actually stills work, but I'm just curious.
Is the volume control built using a single resistance element with fixed taps to the resistance element near each end, or are there separate resistance elements for the taps and a shared wiper. Of course, I'm only talking about one of the two gangs, here.
And what's the relevance of that?.
I'm guessing he's trying to show that a 5-terminal pot can also be made with two pots but the design ends up with two wipers and that's completely different from the 5-pin pot with one wiper in the OPs schematic so you shouldn't do that? Maybe?
The pot shown in post #6 is just a stereo volume pot using a shared ground pin for the two pots, presumably to give it a smaller footprint. The sort of thing you get in car radios.
There used to be, years ago, a company who made DIY pots, you ordered all the separate parts and built your own, as many gangs as you wanted, taps for loudness, log, anti-log, mains switches, anything you wanted you could build. It obviously wasn't cheap, and we never had occasion to order any, but it was always nice to know that a solution was available if required - but I don't remember if they had double tapped tracks or not?.
OK, thanks, not familiar with the overall circuits using these.
Interestingly, the Alps RH27 type I linked to above is a resistor chain based "pot" so it could be possible to add other taps to it??
If you knew where the taps were :D
Although I suppose you could measure the resistance from the taps to the ends etc.
However, it's only an old valve radio, just bang a normal pot in :D
I just thought of something, although the original schematic was hard to read and clipped.
It doesn't give me any useful filter shapes but the pot arrangement is easy to make with 2 ganged wipers in a 5 pin pot.
But if I move the 22k to some high impedance bias, then it behaves like I expect it should going from treble boost to cut with bass boost in one full turn. How slick is that?
I still prefer my Bogan Tube Stereo that had a -15 contour switch. If the phone rang, I hit the -15 dB midrange switch like a Fletcher Munson attenuator and the midrange was cut -15 dB and Bass/Treble only -3 dB. Then when call ended, return to 0 dB flat and loud.
