up/down counter
kilwa-san
hi everybody
can some one explain to me how this counter works
its: Ctr BIN 4bits prog-CTR-PIPO-RAZ sync
:confused:
(PS: i only have basic infos about electronics == i suck )
help please
hi everybody
:confused:
help please
It looks like this type, view the pdf
  • 74LS193.pdf
It would help if we knew the part number.
you mean this : 74HC163
i realy don't get the data sheets so if sombody could explain to me how to make it work as up and down counter ...
thanks
The 74HC163 is a binary "up" counter. It is not an up/down counter.
If that's the device you're looking at (74HC163), it's not an up/down counter. Counts up only.
Here's the datasheet. Look at the timing example on page 9. It shows the counter being preloaded with a value (12) and the count cycles started, counting up to fifteen rolling over to zero, counting to two and stopping (count enable inhibited). Does that help?
It's a fairly complex little device. You need to become familiar with the nomenclature and terminology. "Px" are parallel inputs. "Qx" are outputs. The rest are basically mode-setting and enable/disable lines.
