futz
Active Member
Hey! That's good! Works in the sim. Now to put it into my actual code and test hard.Pommie said:Here is a rather ugly solution,
Thanks Mike!
#include <pic.h>
#include <htc.h>
#include <stdlib.h>
#include <stdio.h>
__CONFIG(XT&WDTDIS&LVPDIS);
void lcd_line1(void); //function prototypes
void lcd_line2(void);
void lcd_cmd(unsigned char);
void lcd_char(char);
void e_togg(void);
void lcd_init(void);
void lcd_string(char *);
void lcd_busy(void);
unsigned char read_a2d(void);
void delay(void);
#define E RD2
#define RS RD0
#define RW RD1
#define busyflag RB3
#define RW_TrisBit TRISD1
#define D7_TrisBit TRISB3
char number[] = " ";
int main(void)
int voltage;
unsigned char a;
long fract;
char fract1,fract2;
ADCON1 = 0b00001110;
ADCON0 = 0b10000000;
ADON = 1;
TRISB = TRISD = 0;
RW = 0; //set R/W low
E = 0; //set E low
lcd_busy(); //wait for LCD to settle
lcd_init();
while(1)
a = read_a2d();
lcd_line1();
voltage = a;
voltage*=5;
fract=((((long)voltage*100)/255)%100);
fract1=(fract/10)%10;
fract2=(fract)%10;
voltage/=255;
sprintf(number,"A2d = %d.%d%d volts",voltage,fract1,fract2);
lcd_string(number);
delay();
ADGO=1;
while(ADGO){}
return(ADRESH);
void lcd_string(char *senpoint)
while(*senpoint != '\0')
lcd_char(*senpoint);
senpoint++;
void lcd_busy(void)
RW_TrisBit = 1; //make R/W input (read)
D7_TrisBit = 1; //make D7 input
RS = 0; //set RS low
RW = 1; //set R/W high
E = 1; //set E high
while(busyflag); //wait for busy flag to go low
E = 0; //set E low
TRISB = 0; //make D7 output
RW_TrisBit = 0; //make R/W output (write)
lcd_cmd(0x80);
lcd_cmd(0xc0);
void lcd_cmd(unsigned char letter)
lcd_busy();
PORTB = letter; //put char in PORTB
PORTB = PORTB >> 4; //shift over to output high 4 bits
RS = 0; //RS low
e_togg(); //latch the data
lcd_busy();
PORTB = letter;
RS = 0; //RS low
e_togg(); //latch it
void lcd_char(char letter)
lcd_busy();
RS = 1; //RS high
lcd_busy();
PORTB = letter;
RS = 1; //RS high
void lcd_init(void)
PORTB = 0x03; //send 3
e_togg();
lcd_busy();
PORTB = 0x03;
e_togg();
lcd_busy();
PORTB = 0x03;
e_togg();
lcd_busy();
PORTB = 0x02; //send 2 - set 4-bit mode
e_togg();
lcd_busy();
lcd_cmd(0x28); //set 4-bit mode and 2 lines
lcd_busy();
lcd_cmd(0x10); //cursor move & shift left
lcd_busy();
lcd_cmd(0x06); //entry mode = increment
lcd_busy();
lcd_cmd(0x0d); //display on - cursor blink on
lcd_busy();
lcd_cmd(0x01); //clear display
lcd_busy();
void e_togg(void)
E=1;
E=0;
void delay(void)
int x,y;
for(x=0;x<1;x++)
for(y=0;y<10000;y++){}
int Voltage;
unsigned long Fixed;
Voltage=104;
Fixed=((long)Voltage)<<16;
Fixed*=5;
Fixed/=255;
FpToString(number,Fixed,2);
void FpToString( char * String, unsigned long Number, char Digits){
unsigned long work;
int divider=10000;
char chr,i,poss=0;
char LeadingZero=1;
work=Number>>16;
for(i=0;i<5;i++){
chr=work / divider;
work-=chr*(long)divider;
if(chr!=0 || LeadingZero==0 || i==4){
String[poss++]=chr+0x30;
LeadingZero=0;
divider/=10;
String[poss++]='.';
work=Number&0xffff;
for(i=0;i<Digits;i++){
work*=10;
String[poss++]=(work>>16)+0x30;
work&=0xffff;
if(work>0x8000 &&String[poss-1]!='9'){ //is remainder > 0.5?
String[poss-1]++; //round up last digit
String[poss]=0;
Excellent! I'm sure I'll find a use for that. I'll test it out tomorrow. I'm going blind from too much time at the computers.Pommie said:Here's a slightly more elegant solution using 16.16 fixed point maths. The FpToString function suppresses leading zeroes and returns a number of places after the decimal point defined by Digits.
void init_a2d(void)
ADCON0=0; // select Fosc/2
ADCON1=0; // select left justify result. A/D port configuration 0
ADON=1; // turn on the A2D conversion module
unsigned char read_a2d(unsigned char channel)
channel&=0x07; // truncate channel to 3 bits
ADCON0&=0xC5; // clear current channel select
ADCON0|=(channel<<3); // apply the new channel select
ADGO=1; // initiate conversion on the selected channel
while(ADGO)continue;
return(ADRESH); // return 8 MSB of the result
void main(void)
unsigned char outString[20];
float voltage;
unsigned char x;
init_a2d(); // initialise the A2D module
GIE=0;
TRISE = 0;
TRISD = 0;
TRISB = 0;
TRISA = 0x01;;
ADCON1 = 14;
RE2 = 0;
DelayMs(500);
lcd_init();
while(1) {
lcd_clear();
lcd_goto(0);
lcd_puts("Damn!");
x=read_a2d(0);
lcd_goto(40);
//lcd_puts("Since I use LCDs :-)");
voltage=(x/255.0)*(5.0); // this equation must convert the reading into voltage
sprintf(outString,"A2D = %d volts",voltage);
lcd_puts(outString);
DelayMs(3000);
Hahahahahaha!!!engkhlaif said:is the code of Futz suitable for my purpose and i cant compile it using MPLAB !!!!
fisrt of all it seem that my language is not enough to tell what iam exactly wantfutz said:Hahahahahaha!!!![]()
We do the work for ya and you still can't figure it out? Hilarious!
Not only did you say before that you wanted to display voltage - not distance, but your code was trying to display voltage - not distance. Anyway, it's easy enough to convert.
What compiler do you use?
while(1) {
lcd_clear();
lcd_goto(0);
lcd_puts("Damn!");
x=read_a2d(0);
// lcd_goto(40);
DelayMs(3000);
u misunderstand me!!!Pommie said:We're 5 pages into the thread and you state that you can't compile with MPLAB! I'm hoping it's a language thing. You now have working code, if you can't turn that into a usable project then you do not deserve to be given the title Electronic Engineer or any other such title. Just checked, there is no sad smilie.
Geesh engkhlaif, try to follow the conversation. Start reading this thread somewhere back on page 3. Read all the messages. You'll see that we went over this problem and found the probable cause (definite cause in my case) and a pretty good solution too.engkhlaif said:when i compile the first code i posted it gives me an output voltage that is impossibe and here the code
Code:while(1) { lcd_clear(); lcd_goto(0); lcd_puts("Damn!"); x=read_a2d(0); // lcd_goto(40); //lcd_puts("Since I use LCDs :-)"); voltage=(x/255.0)*(5.0); sprintf(outString,"A2D = %d volts",voltage); lcd_puts(outString); DelayMs(3000); } }
htc.h is a Hi-Tech PICC compiler thing. You're going to have to make some small changes to suit your compiler.engkhlaif said:i mean that when i compile the code it gives me an error: cannot include htc.h it seem that my MPLAB doesnt contain
any way iam very pleasure to thank u and to ur care
ok i get it iam using PICC in MPLAB enviroment i will ry every thing you and pommie told me about and i hope that i will get resultsfutz said:And MPLAB is NOT a compiler. It is an IDE, or Integrated Development Environment. You can use many different assemblers and compilers with MPLAB.
#include <pic.h>
#include <htc.h>
#include <stdlib.h>
#include <stdio.h>
void e_togg(void);
void delay(void);
#define E RE2
#define RS RE0
#define RW RE1
#define RW_TrisBit TRISE1
int main(void)
int voltage;
unsigned char a;
long fract;
char fract1,fract2;
ADON = 1;
TRISB = TRISE = 0;
E = 0; //set E low
lcd_init();
while(1)
a = read_a2d();
lcd_line1();
voltage = a;
voltage*=5;
fract2=(fract)%10;
voltage/=255;
lcd_string(number);
delay();
ADGO=1;
while(ADGO){}
return(ADRESH);
senpoint++;
void lcd_busy(void)
E = 1; //set E high
E = 0; //set E low
lcd_cmd(0x80);
lcd_cmd(0xc0);
lcd_busy();
RS = 0; //RS low
lcd_busy();
PORTB = letter;
RS = 0; //RS low
lcd_busy();
RS = 1; //RS high
lcd_busy();
PORTB = letter;
RS = 1; //RS high
void lcd_init(void)
e_togg();
lcd_busy();
PORTB = 0x03;
e_togg();
lcd_busy();
PORTB = 0x03;
e_togg();
lcd_busy();
e_togg();
lcd_busy();
lcd_busy();
lcd_busy();
lcd_busy();
lcd_busy();
lcd_busy();
void e_togg(void)
E=1;
E=0;
void delay(void)
int x,y;
for(x=0;x<1;x++)
}[CODE]
i have modifeid ur code to get the controls of LCD at pins 0,1,2 of PORTE
as u see above
but the problem that when i connect the power the LCD givesa ablank
i connedt the output of LCD AS below:
LCD PIC
11 RB4
12 RB5
13 RB6
14 RB7
First, when you use code tags, the end tag needs a / before the word code or you get the mess you see in your post. Always preview your post to see what it looks like before posting.engkhlaif said:i have modifeid ur code to get the controls of LCD at pins 0,1,2 of PORTE as u see above but the problem that when i connect the power the LCD givesa a blank i connect the output of LCD AS below:
LCD PIC
11 RB4
12 RB5
13 RB6
14 RB7
Nothing wrong with that. But you need to understand the code so you can modify it. You posted my code above with a couple minor mods, but you haven't made the most important modifications necessary. As posted it will NOT work as long as your LCD data lines are at RB4 to RB7.engkhlaif said:first i will be very clear with u
the code i have posted i make a modification on it so that i can suit it with my purpose you know this is my lasy semester and iam registered to 20Hours (9 cources)
the original code i get it from the samples in the HI-TECH when i install the MPLAB
and about the LCD why i connedt it to the high (B4-B7) the code i poste it at the begenning of my posts requires to do that !!!
so is that to get a sample code and then modify it to suite ur ampition wrog thing!!! advice me
