kalyan_chakri31
hii
i am working on some project and i want to connect and record the output from electret mic in the osciloscope. the problem i am facing is that when the mic is connected directly to the osciloscope...i cannot see anysort of signal in the osciloscope.
i have tried to make an amplifier using 741 op-amp but was not able to get anything. i am not from electronics background so i hope i didnot made a good circuit.....if i use a mic pre-amp then will the output from this mic pre-amp be sufficient to see a good signal in the osicloscope. are there any readymade kits available onime so that i can buy 1. i've seen one of such kind online but im not sure if that could solve my problem....somebody please guide me correctly ....
the above two links are the kits i am talking about. will these be helpful to me if i replace the mics in these circuits with what i need?
