Using PC to control Opto-Isolators
Designer
Hey there,
I'm stuck on a little project, im looking for a way of controlling 512 Opto-isolators from my PC (1024 would be better if possible) under Visual Basic.
I'm wondering what the best way to accomplish this would be as im working on a very tight budget. I would prefer to take the route of having control from the USB port or 9 pin serial in a way i can use the MSCOMM32 OCX as my PC seems very unstable using parallel port control (used a Velleman K8000 for a while and worked very erratically).
I can see a few ways of doing it with just a PIC but cant figure on a way of using serial comms with multiple pic's unless i could switch the serial connection between the multiple pics at high speed.
Any ideas?
You don't say if the output from the optos needs to be steady or if it can be pulsed. If the latter is ok, then you could use a pic to receive the serial data from the pc and convert it to a suitable data stream to send to LED matrix drivers, such as Maxim's MAX6960, 61, 62 or 63. Each of these chips will drive 64 leds at a time (in an 8x8 matrix), but they will be multiplexed. These chips cost about $6 US. You could use any of several other Maxim chips to do the same thing, but their outputs will also be multiplexed. Look for those chips with 8 digits and 7 segments+DP.
JB
