using printf for two usart in stm32
tariq70
hi
I'm using stm32 by keil5 compiler and This is my printf function
C:
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#define GETCHAR_PROTOTYPE int __io_getchar(void)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#define GETCHAR_PROTOTYPE int fgetc(FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
    HAL_UART_Transmit(&huart1,(uint8_t*)&ch,1,100);
        return ch;
in this code my printf only sends data in uart1. is there any function to send data by printf and choosing uart.
for example my printf become like this :
printf(&huart2,"HELLO WORLD"%d,variable)?
Thankyou.
If you read the C compiler documentation ( I am unsure here as I use Microchip) you provide the putch() and getch() to source the input / output to suit.. You could simple swap the default before sprint() is called...
In your example.. &huart1 is a handle so make anther to handle port 2
Do not use the handle in the sprint() statement printf and sprint are looking for a character array and not a destination output
C:
PUTCHAR_PROTOTYPE
      if(SERIAL == 1)  HAL_UART_Transmit(&huart1,(uint8_t*)&ch,1,100);
      if(SERIAL == 2)  HAL_UART_Transmit(&huart2,(uint8_t*)&ch,1,100);
      return ch;
Even this doesn't look right... I would rewrite their __io_putchar() function..
I tend not to use printf, as it loads a huge library, but I use a very similar system to select either serial port - or sometimes one of three.
C:
void Serial_Write(char port, unsigned char value)
    if (port==1)
        EUSART1_Write(value);
    else if (port==2)
        EUSART2_Write(value);
