Thunderchild
well I'm selling them locally directly to a private buyer
You don't happen to have any 6JS6's do you?
I have been trying to get my old ham radio transmitter back on the air, and can't get much power out of it. Its old and uses valves. I am thinking I may have one that has gone bad.
I was actually just researching how to test valves yesterday. This topic came up at a good time for me.
My dad has several of those suitcase style valve testers in his basement. But as Rolf said, I am sure they need some TLC before they are going to work again.
The only thing which can go wrong with a tube is the cathode. It is coated with barium which produces a "cloud" of electrons when heated. The electrons move towards the positive anode controlled by the grid.
Reducing the filament heating power will not be satisfactory when testing a tube.
You can refresh a tube by applying high voltage to the cathode and the grid to burn off the used barium.
This procedure requires close watch. After that the tube might be completely worthless or work like new.
Boncuk
I must have replaced over 2,000 values in 15 years of doing 35,000 TV repairs.
I must have replaced only a dozen valves that did not light up.
Yes, I am quite a ways from the UK. Just thought i'd ask incase you had a bunch of them or something. They are used as the final tubes in my transmitter and are out of production and a bit hard to find.
he has manily radio valves
Let's not overlook when they "get gassy" - as in lose some or all of that vacuum. Usually you *will* lose the heater when that happens. Not always though.Elements can twist and short (or shout, microphonics) or just change the characteristics. Solder connections can open at the base. Sockets can go bad and THAT can drive you crazy.
eBay search comes up with 4 hits:You don't happen to have any 6JS6's do you?
sorry I just got dad to check his list and he hasn't got any, he has manily radio valves
6JS6, Electronics items on eBay.com
Oops, just scrolled down. I mean "8 hits".
Since this topic is already kinda off topic, i'm going to just ask....
What causes the top of a valve to get shiny? Does it have to do with metal migrating up there over time, kind of like a fluorescent lightbulb gets black on the ends? Is the amount of shine dependant on the amount of use a valve has had?
