The low frequency resonance of a speaker causes it to be a lousy microphone.mstechca said:Input is just input. and if the input is a speaker, check it's resistance, and then treat it as a resistor.
In fact, connect a speaker to a circuit of some sorts, and to a motor, and see if you can power the motor from the techno music in the room! :lol: :lol:audioguru said:I know what you can do with the speaker: spin it! :lol:
walters said:varactor diodes the capacitances are in the picofarads
Can i use Varactors in "series" to increase the capacitances?
Or i would need a "Custom" Varactor diode to have the capacitance in the microfarads?
What would the Varactors doping process do different and how? the PN junction needs to be Bigger?
I need a Varactor is the Mircofarads? which ones is there please?
u cannot (practicaly)get a uF varactor. afaikwalters said:thanks for the help
How can i get a a uF varactor?
I need uf Varactors?
How can i make one or put them in series or so to make a uf varactor?
it requires a large depletion layer region (large area).walters said:why not?
AFAIKwalters said:So i have to get this Custom made to have a large depletion layer region (large area)?
walterswalters said:A large depletion layer region large area would give me more capacitance to be mircofarads?
Most Varactors are used:
tunable filters and oscillators , frequency multiplication and frequency mixing
if u have got some capacitor and a measurement eqp: , try it out and check what happens.walters said:put another one in series? or 3 or 5 in series? to ADD them?
audioguru wrote :walters said:Yea but i still can't Vary the Varactors in Mircofarads i need to have a variable .01uf or .47 or 220uf Varactors i wish they made these
I need to use the .01uf Varactors in a phase shift network filter for audio not radio
RepeatA 0.22uF capacitor's effective value in a filter circuit can be changed with PWM. With 100% duty-cycle it is 0.22uF. With 10% duty-cycle it is 0.022uF. With 1% duty-cycle it is ..., you figure it out. Of course, the frequency of the PWM is very high so can't be heard.
You also didn't hear me describe how PWM can vary the capacitance over a wide range of any capacitor. I've used switched-capacitor lowpass filter ICs for years. They switch internal capacitors similar to PWM and work perfectly.
