VBA copying picture in Image control to another Image control in different UserForm
atferrari
Most Helpful Member
VBA Excel
Two UserForms:
a) LayerAndFrameSettings with several Image controls. Amongst them: LED_1, LED_2, LED3, LED_4
b) Luminosity with five Image controls: Level_1, Level_2, Level_3, Level_4, Level_5
All data (single variables / arrays) is declared As Byte, enough for the values in play.
Code, based on external values is expected to copy the picture in one of the image controls at Luminosity
to one of the LED_X Image controls at LayerAndFrameSettings userform.
After extensive testing found that:
The following sentences do it properly
   LayerAndFrameSettings.Controls("LED_4").Picture = Luminosity.Controls("Level_" & CStr(LayerLuminosityData(Pntr_LED))).Picture
   LayerAndFrameSettings.Controls("LED_2").Picture = Luminosity.Level_4.Picture
   LayerAndFrameSettings.Controls("Middle_square_change").Picture = Luminosity.Controls("Level_" & CStr(LayerLuminosityData(Pntr_LED))).Picture
   LayerAndFrameSettings.Controls("Inner_square_change").Picture = Luminosity.Controls("Level_4").Picture
   LayerAndFrameSettings.Controls("Middle_" & "square_change").Picture = Luminosity.Controls("Level_" & CStr(LayerLuminosityData(Pntr_LED))).Picture
   LayerAndFrameSettings.LED_3.Picture = Luminosity.Controls("Level_" & CStr(LayerLuminosityData(Pntr_LED))).Picture
BUT the following do not copy any picture at all and Excel does NOT raise any error at runtime
   LayerAndFrameSettings.Controls("LED_" & CStr(Pntr_LED)).Picture = Luminosity.Level_2.Picture
   LayerAndFrameSettings.Controls("LED_" & CStr(Pntr_LED)).Picture = Luminosity.Controls("Level_" & CStr(LayerLuminosityData(Pntr_LED))).Picture
Just in case I checked in the worksheet, the values below and they display OK
   Range("FY4").Value = "LED_" & CStr(Pntr_LED)
   Range("GB4").Value = "Level_" & CStr(LayerLuminosityData(Pntr_LED))
   Range("GD4").Value = LayerLuminosityData(Pntr_LED)
I am supposed to use a string to identify which control is receiving the picture, right?
Probelm somehow solved.
I changed to Label controls and it works OK now. Pity is I cannot say why the Image controls did not work.
