sensor on the running gear will do the job..
Aaarrhh..........Your loco's are a little larger than mine me thinks!
Willy
The trouble I have is the old Triang's wheels are too large.. I will have to turn them down... I have several newer engines but as you say, a bit smaller.
I have motors in abundance... I have already replaced most of them... Two are the motors you described they are in the tender.. I have machined the tender to take the newer motor and I have now a jig to machine down the wheels to fit on a standard rail. I don't have much Triang track anyway! Don't get me wrong.. I have quite a bit of Hornby, I just don't have DCC yet!... Yet!!! It'll be something to do...The engines have to be at best 50 yrs old, old XG4 ( was that what they were called?) 3 pole motors, probably need re-magnetizing etc.
cpc is just around the corner from me, allthough I tend not to use the trade counter as they make you stand for an hour.
As for old magnets, I have a bicycle hub dynamo, pre war, it had an alnico magnet its been replaced with neo's and still works fine.
I dont notice any difference at all, it takes 200 - 300 watts to push a cycle, and draining 5 off for the lights isnt much, unlike a bottle dyamo your not creating loads of friction, I build my own wheels, even tried a 32 spoke sturmey archer dynohub on a 36 spoke wheel.
The barracks is just round the corner, I used to frequent the barracks chippy, till the old dear sold up now its not as good.
The garrison pub is no longer, I think its going to be a retirement centre.
Tell me the functions you need, I'll write some code ( I'll even program a chip and send it to you) All I need to know is functionality.
BTW.. The SD card idea has failed... Too noisy... I thought it might be.. Booster station seems to work ok... I have a little Arduino as my decoder... Just LED's for functions... I won't give up though!! I'll have a sound card working soon..
I was also wondering how you get the data out? Lets assume the loco has a switched output on the running gear ( I'm trying one out next week, I'll let you know how I fair).. Its the same idea that I use in my anemometer Anywho... The DCC is a one way communication system... How do you get the data back to the throttle?
As far as the pot's concerned, There is enough time to oversample ( smoother output ) I normally oversample by a factor of 24... It will feel more like a 12 bit input ( 4092 steps)..
I mainly use pic's.... Any pic would do the job.. My favourite pic of the month is the pic12f1840... I use them daily!!That sounds brilliant. Can you tell me which micro you would suggest as I would like to read up on it so I can have a better understanding?
