yes something pretty simple because all i learned is some simple gates and full adderdo you just want to make only with Gates?????
i didnt understand a wordBuild a circuit that takes in two quadrature encoder signals and translates them to "direction" and "clock" signals. Then add a counter to show "wheel position".
these are technical stuff i would like something that even normal people would understand like a timer or something1. An 8-bit full adder with carry in and carry out.
2. A 2 bit by 2 bit multiplier.
3. A 4 bit counter with JK flip flops made from discrete gates.
Allen
that sounds great explain more pleaseHow about an electronic dice?
you can use 7400 for primarily alarm system in bread board ...yes something pretty simple because all i learned is some simple gates and full adder
hope you have some basic knowledge of resistor and transistor, LED, Buzzer?????
no i dont .. like i said all we used in the lab are AND , OR , XOR gates on the board using NAND ICs and wires and batteries so its pretty basic stuff ..
what you exactly do. if you elaborate.AND , OR , XOR gates on the board using NAND ICs and wires and batteries so its pretty basic stuff ..
