voltage divider
The output voltage changes if the load current changes.
An active regulator keeps its output voltage constant regardless of the output current (ideally).
samtheboxer said:
i found this link http://hyperphysics.phy-astr.gsu.edu/hbase/electric/voldiv.html and was wondering how this differs from a voltage regulator?
i blew up my NTE960 today and was thinking that if i go this route, i could bring and 11v source down to 5v to use with my PIC.....would that work?
The voltage divider using resistors is normally only used to divide a voltage signal level. As eng1 says the voltage to the PIC supply rail will vary according to how much current the PIC requires at any instant.
A 7805 voltage regulator will do the job and its a pin for pin replacement for the NTE960.
Eric
It is nearly impossible to blow up a 7805 regulator.
It limits the current if it gets too high.
It shuts down if it gets too hot.
