input power to the scope is just 120v, 1ph, US power. Will be testing 3ph
...Surely there is a common way to islolate a power supply for the scope so it can test grid power?
I understand the problem with connecting the grounds.Crutschow, I think I am also a bit confused on your reply. How would the 10x leads fix this? I think the concern was that the neg lead on the scope is directly coupled to the input ground so if I connect that neg lead to a common or ground that is a mutual connection with the scope input power, bad things happen. Surely there is a common way to islolate a power supply for the scope so it can test grid power?
The ratio (differential) probes that Ron mentioned have everything included to perform high voltage isolated differential measurements.As I understand it, the ratio probes have a built in isolation transformer so pretty much cover the voltage reduction and isolation requirement in one shot?
So far, it looks like a "math scope" is what we are looking for. Found one but price was 20 grand and just cannot spend near that amount. Certainly open to ideas to test these criteria. For this app, the IGBT processor operates at only 20khz.
The problem is finding such an oscilloscope. I don't know if anyone makes such a unit.If we are looking to buy a scope, would it be best to just get a differential scope to reduce costs with isolated leads and such?
