I have an Alfatronix PS3 24v dc to 13.6v dc powerverter and require to reduce the output to 12v. Is there a compnent that can easily be utilised in-line with the output to achieve this?
... i'm using it to run an asus net book from a 24v supply. The netbook's ac power supply has a stated output of 12v dc 3a, the output measured with a multi meter is 12.2v. ...
would this be a suitable diode to use:
Part Max. recurrent Max. RMS Max. DC blocking
number peak reverse voltage voltage
P600A 50V 35V 50V
Specifications:
Max. Average forward rectified current: 6A
Peak forward surge current: 400A
Max. DC reverse current: 5uA
Junction capacitance typ.: 150pF
Temperature range: -50 to +150 C
number peak reverse voltage voltage voltage
