samson.bunty1986
Dear all,
How to sense mains voltage(230VAC) from micro-controller?
Dear all,
Hi ericgibbs,
Yes,i would like to detect whether Mains is there are not by using controller. So kindly suggest me how to do this??
My transformer secondary is 24V..so i need to take from that using voltage divider?? is it safe??
Hi Ericgibbs,
Yes ,the 24V transformer is used in battery charging circuit,stepping down 230V to 24V. I would like to take instant voltages of secondry AC and i will operate mosfets. I will take these inputs as ADC for controller.
That waveform will get after rectification only..Right??? But i would like to sense the voltages before rectification...can it be possible?? May be i will get negative voltages also?? can i give negative voltages to controller??
The option which you have given is good. Will this work if i connect like that??
Hi Ericgibbs,
Can you please tell me how to offset the sinewave to 2.5V. Am new to this.
My actual project is battery charger. I would like to sense the mains voltage to operate relay for mains mode and battery mode. And second purpose of sensing the mains is: In positive half cycle i need to operate one mosfet and in negative half cycle i need to operate another mosfet for charging a battery.. This charger is a single stage battery charger..
