Voltage to current calculations
adrianvon
Hi all,
With reference to the attached schematic and derivation;
I can understand that Io = Ir2 - Ir3 = Ir1 - Ir3 , but what is the procedure followed for the next 2 steps please?
Hi all,
The voltage at the node of resistor R3 and the LOAD is (vi R2)/R1. Do you understand that? So the current through R3 will be (vi R2)/(R1 R3) . The current io will be Ir1 minus Ir3, not Ir1 plus Ir3 like the answer key says. Therefore, the answer will be vi/R1-(R2/R1 vi) 1/R3 and the R term will have a minus sign in it.
Ratch
Ratch did you forget that the voltage gain for this circuit is negative and this is why we have a plus sign in equation vi/R1 + (R2/R1 vi)*1/R3??
Yes, you are correct. Sorry for the mistake. I should have been more careful.
Ratch
