VU meter, LM3915 Help.
Instructables are designed by people who know nothing about electronics.
Look at the datasheet for the LM3915. It shows a resistor between pin 7 and pin 8 that is missing in this circuit. The value of the resistor from pin 8 to ground is very high so the LEDs brightness will be low. Also missing is an important supply bypass capacitor. Also missing is a peak detector circuit that is recommended and a few are shown in the datasheet.
Are you sure o -o
Do you think I should use like 10k instead of 10k from 8 to ground?
I corrected the errors. Make it like this:
