I have a 16x2 I know I want it to be connected to my PC and I will be putting it in my floppy drive bay.
But I have a question since I've never used this type before I'm unsure how to get it to work right..
I do have the data sheet for it which connection should I use for connecting to the pc?
I was going to use the program LCDsmartie if anyone heard of that program before.
Here is the Pin out for the Display.
Pin No. Symbol Level Description
1 VSS 0V Ground
2 VDD 5.0V Supply Voltage for logic
3 ※VBT (Variable) Operating voltage for PLED Brightness adjhstment
4 RS H/L H: DATA, L: Instruction code
5 R/W H/L H: Read(MPU→ Module) L: Write(MPU→ Module)
6 E H,H→ L Chip enable signal
7 DB0 H/L Data bit 0
8 DB1 H/L Data bit 1
9 DB2 H/L Data bit 2
10 DB3 H/L Data bit 3
11 DB4 H/L Data bit 4
12 DB5 H/L Data bit 5
13 DB6 H/L Data bit 6
14 DB7 H/L Data bit 7
15 NC -
16 NC -
I hope someone could help it's been sitting in my bin for a little over a year.
1 VSS 0V Ground
15 NC -
16 NC -
