Krumlink said:I am about to restock on parts, and I was wondering what type of analog chips I should get, such as op amps, comparators, etc that you commonly use, not to mention anythign else you enjoy using, as I need to restock.
(PS I am ordering from Jameco)
The 5V devices are useful but it you're stuck for space, all you really need are some LM317s and LM337s; you can get different voltages by using different resistors.Leftyretro said:And of course a variety of 3 pin linear regulator chips of various negative and positive voltage values are always in big demand.
Marks256 said:that is another thing i was thinking... i wonder if they allow that? I don't see why not... either way, i need some max232 chips, a bunch of 74ls series chips, a few hundred feet of wire some resistors, capacitors, diodes, LEDs, and, most importantly of all; a multimeter.
wikipedia said:I2C is a multi-master serial computer bus invented by Philips that is used to attach low-speed peripherals to a motherboard, embedded system, or cellphone. The name stands for Inter-Integrated Circuit and is pronounced I-squared-C and also, incorrectly, I-two-C. As of October 1, 2006, no licensing fees are required to implement the I²C protocol.
Marks256 said:a bunch of 74ls series chips
I²C on Wikipedia. I've been seeing it quite a bit myself lately (haven't been much into electronics until recently and barely into anything complex).Marks256 said:i could look it up, but that would require me to move my mouse to the top of the screen, open a new tab, and google i2c... too much energy required... X-D
Marks256 said:i was going to get a large assortment from jameco. I think there was like 2700 resistors (27 different values, 100 of each) for $24 from jameco.
dumb question; what is I2C? I keep seeing that everywhere...
Those op-amps are good for audio, I'd go for some of the quad and single versions too. The single versions are handy as you can trim the offset and they use less current than a double if you're only using half of it. The quad versions are handy as they save board space of you need three or four amplifiers.speakerguy79 said:TL072 and NE5532 are good dual op amps for dual supply applications. Popular in audio. Both are very inexpensive.
