Hello,
We wish to put an RF receiver and transmitter inside LED warning beacons on trucks. They will be used to receive data pertaining to which type of flash pattern they should be showing.
There will be another receiver and transmitter in the truck cab, for the driver to communicate to the beacon with.
We will use this receiver and transmitter….
AM-HRR30-433 (£4.97) miniature receiver module datasheet:
https://www.rfsolutions.co.uk/acatalog/info_AM_HRR30_433.html
AM-RT5-433 (£5.71) Transmitter datasheet…
https://www.rfsolutions.co.uk/acatalog/DS013-9%20AM-RTx.pdf
..these are said to be good for 50 metres when used with the lambda/4 antenna…
FLEXI-M4-433 antenna datasheet (1/4 wave) (£3.95)
https://www.rfsolutions.co.uk/acatalog/DS016-13_AM-HRR.pdf
We do not want to use the antenna, what range do you think we will get without the antenna?
In fact, instead of the proper antenna, we may just solder a 17cm bit of 7/0.2mm wire to the antenna pin.
We will just leave the wire coiled into whatever position it ends up in, as it wont be perfect, but surely better than nothing? What range do you think we will get? (Its only 15 metres from truck cab to the warning beacon.)
