Sanding the tip is one of the worst things you can do. Tips are made of copper. Copper will alloy with solder if it is in direct contact, causing the tip to get pitted. For this reason, tips are plated with a metal (e.g., iron) that does not easily dissolve (alloy) in solder. Sanding will remove the plating, ruining your tip.I'll leave the iron as it is. Probably no solder left. Next time when taking there I can see some black dust on the tip. I will scratch it using a sandpaper and apply solder sometimes it refuses to catch try again and when a small ball catches, scratch the tip on the asbestos sheet to make it a uniform distribution over the tip. It's OK! I'm using my iron as a driller also for making holes on plastic boxes. After drilling I'll clean it using a dry cloth keeping the iron ON then again sand paper it. Clean! Again the process repeats for next soldering. My iron is almost 7yrs old. I haven't replaced the tip till now. Occasional use only.
How to know that the iron is getting hot.
When my iron is switched ON I'll be on a confused state that whether it is getting warm or not. After a few seconds I'll take it close to my face and u know our face can sense heat easily. Not recommended!
A few times I've taken the iron at its hot end without knowing.
as the tip is made of copper it will hardly oxidate (rust) or corrode much...
I melt solder onto it and then dunk it once into a brass sponge thing to even out the solder coat and turn it off. I don't use a moist sponge. Don't like it. Steals the heat and never seems to behave the way it should.
Steals the heat? What kind of iron do you use?
Solder stations have that little sponge tray for a reason.
So you're saying that if you wipe your tip on your moist sponge, the solder on the tip doesn't solidify? Because I find that a little hard to believe.
Maybe I was doing it wrong when I started out and moved onto brass sponges and never looked back. Either way, I'm too lazy to find distilled water now.
In my many years of soldering, I have never used distilled water. It makes sense that this may be better, but a moistened sponge with tap water works just fine.
Is distilled water the stuff contained in battery "water"? If so, I can't use it, because I don't get them separated.
