Which PIC do I use?
Would you believe after only a week I've already used an 'overload' function? I didn't even realize that was a new feature. Very cool!
Mike
//  function prototypes
void PutLCD(unsigned char ptype, unsigned char pbyte);
void PutLCD(rom char *pdata);
//  example ->  PutLCD("K8LH Clock");
  char n = 0;                    //
  char temp;                     //
  while(temp = pdata[n++])       //
    PutLCD(dat,temp);            //
Guess I'd better get off here and get some work done! :D
Thanks for all the advice guys. Got myself some 16f628's and going to start learning on those, and I will take a look at the different compilers mentioned.
Txs again
Magen
Hola Mike,
I know nothing about C.
What the "overload" function does?
Intrigued.
Hola Mike,
Intrigued.
Aparently not enough to look it up :)
Try this https://www.redhat.com/docs/manuals/database/RHDB-7.1.3-Manual/prog/xfunc-overload.html
For the most part what it means is that you can have several functions with the same name and the compiler tells them apart by the number and types of paramets used in the call. Also see function signature.
A function's signature is a combination of the function's name; the number, order, and types of its parameters; as well as any qualifiers that can be applied to the function.
