Same here throbs, never twice the same colour isnt what it stands for, I think (about to be corrected) it stands for national televison system comittee,
they also said at college pal stands for perfect at last.
Pal contains a colourbust signal that calibrates the colour line by line, ntsc doesnt do that and on old tellys the colour went squiffy to the right of the screen and had to be adjusted every so often.
The volatge in the uk at one time differed as to where you were in the country, most of my valve radios have multiple taps for the mains power.
Some say 50hz was a trade off from a diesel engines max efficiency (which is normally 2200 rpm rather than 3000 req for 50hz), and some say its an efficient speed to run a turbine.
And that SECAM stands for "Something Essentially Contrary to the American Method".When I was at college, they taught us NTSC stands for "Never Twice the Same Colour"![]()
Not sure I understand your statement. The USA grid wouldn't change since it operates at a much higher voltage. And most US homes already have center-tap 240V going to the junction box from the neighborhood transformer. 120V is provided by going from one side of the 240V to the center tap. So the problem would be changing all the zillions of appliances from 120V to 240V.Hi,
I agree that 220vac is better than 120vac because the wire diameter to deliver the same power could be smaller, smaller by close to 26 percent less diameter. That means the 220vac wire could have a diameter about 0.73 times that of a 120vac wire, which of course is smaller and means less copper material to deliver the same power.
In fact, an immediate upgrade to the grid in the USA could be realized if the voltage was turned up to 220vac because the whole grid would then be able to deliver at least 83 percent more power with the same wiring. Trouble is, all the transformers would have to be changed too...which is a big undertaking.
I'm confused. Does this mean if you connect a live wire from one socket in your house, and a live wire to another socket in your house (or maybe your neighbours house), you get 240V?
Fascinating. Goes back nicely to the o/p's question of why we do things in different ways. So US houses have 2 live wires? Huh, strange!
It's even more strange - America commonly used aluminium wiring rather than copper at one timenow that is nasty!.
