I believe you can get 3 phase power by tapping into 2 of your neighbor's power panels. They must be sequential.
I think most residential transformers are single-phase with two wire inputs from the HV line. It would have to be a 3-phase transformer with 3 wire inputs to generate a 3-phase output.I believe you can get 3 phase power by tapping into 2 of your neighbor's power panels. They must be sequential.
Yes, they did use aluminum wiring for a short period of time in homes here, but it was soon abandoned because of the problems. One guy at work had an older home with Al wiring and he said there was a real danger that an outlet could overheat and start a fire. The problem was the Al would develop an insulting oxide which caused a high resistance at the connection to the wall sockets. A large load connected to the socket could then raise the temperature high enough to start the wire insulation burning. The proper way to minimize that was to using special protective grease over all the connections but if that wasn't done properly, you were in trouble.It's even more strange - America commonly used aluminium wiring rather than copper at one timenow that is nasty!.
It's not just the vertical scan rate, which was originally equal to the main's frequency, that determines the resolution, but the ratio of the horizontal scan rate to the vertical scan rate. For a given horizontal rate a 50Hz vertical rate would actually give a higher resolution than a 60Hz scan since it would have more horizontal lines per picture.The power grid and all those nice things were developped in the early stages of technology and communication. Pal is not better (for the most part) because it is newer than NTSC, but because of the 60 Hz. Colour TV uses interleaving technology. The higher the mains frequency, the more lines (sharper pix) you get.
Pal contains a colourbust signal that calibrates the colour line by line, ntsc doesnt do that and on old tellys the colour went squiffy to the right of the screen and had to be adjusted every so often.
But interestingly, the ratio of 625 to 525 is very close to the ratio of power line frequencies (and thus vertical scan rates) between Europe and the U.S. so the horizontal line frequencies are very similar.Sorry, but you are completely incorrect
PAL has MORE lines (625 as against 525) than NTSC, it's not a function of mains of frame frequency - so as well as a superior colour system it has higher resolution as well. This is why HD was important in the USA, because it's a much greater improvement than it is for PAL.
It wasn't so much the oxide as it is the properties of aluminum that it will not hold compression regardless of how tight you tightened the terminal , so when the wire heats and expands, it "squashes", then when it cools, it is no longer tight, and then it can oxide and create heat which creates more "squish" and on and on. The cure was to pig tail a piece of copper wire onto the end of the aluminum wire with either a wire nut or butt spice with the use of Pentrox, One of the a fore mentioned greases that contain zinc. The zinc would penetrate the oxide and the grease would keep the oxygen away for a better connection.Yes, they did use aluminum wiring for a short period of time in homes here, but it was soon abandoned because of the problems. One guy at work had an older home with Al wiring and he said there was a real danger that an outlet could overheat and start a fire. The problem was the Al would develop an insulting oxide which caused a high resistance at the connection to the wall sockets. A large load connected to the socket could then raise the temperature high enough to start the wire insulation burning. The proper way to minimize that was to using special protective grease over all the connections but if that wasn't done properly, you were in trouble.
I'm confused. Does this mean if you connect a live wire from one socket in your house, and a live wire to another socket in your house (or maybe your neighbours house), you get 240V?
Pal is pretty much a subject for conjecture now in the uk, its vanishing quick, eveyones gone dvb.
My local transmitter was 500kw when it was analogue, now its only 10kw, and we can still get a good picture.
I believe NTSC used maximum transistor power for the black level. That is because picture noise is more noticeable in the dark areas of the picture compared the the light areas, and if there is a fixed level of noise, there will be a higher signal-to-noise ratio and thus less noticeable noise, at the peak (black level) of the transmitted power.
that may be true, I don't know, but I thought TV transmission is an FM modulated signal, with the audio being AM modulated. That means you'd have a fairly constant power, with the peaks at the edges of the modulation of the signal.
