I would disagree, a sawtooth has near instantaneous transition in one direction, and a slow ramp in the other.
But regardless, all class-D amps (of this type) use triangle waves - why would you want to use something that would be inferior?.
Really sorry to have to disagree, but ... more stable?Sorry to have to disagree, but a sawtooth works just as good as a triangle and is more stable.
Completely agree, and I think this is a more significant problem than you do. Besides just getting a circuit to behave, the voltage effects and EMI of the large current spike must be dealt with.The disadvantage of the sawtooth wave is that the capacitor has to be discharged (or charged) very quickly and that requires a higher current.
Completely agree, which means this reinforces the corresponding disadvantage of the saw wave.The advantage of the real triangle (ramp up and ramp down) is that there is no fast transition so it's a smoother wave.
Disagree, because of your statement about producing the high current spike needed for the saw wave's fast edge.The disadvantages however are 1. that the <tri> wave is more difficult to produce,
I can't whip out the math, but I challenge you to justify this one. In an identical parallel comparison of two signal chains (tri and saw) with the same comparators generating the PWM followed by the same low pass filters recovering the baseband signal, and a reasonable relationship between the baseband and the carrier, such as a 1.73 kHz tone and 100 kHz saw and tri waves, I don't see any reason for the time or phase delay through the two chains to be significantly different.and 2. that there is a phase shift associated with a triangle due to the pulse edge moving forward in time relative to the cycle time, which could produce an unstable pole.
Where exactly are you seeing this square-wave?Considering the sound using a square wave is decently intelligible and loud, I'll stick with it.
ak
Done. See post #14.we could also do some simulations with both types of PWM generators
