Look at Allpass Filter in Google.ivanseng said:audio guru,
ur allpass filter circuit.. The Rx R and C how to determine the shifting ?
audioguru said:Texas instruments show two Wien bridge oscillators with a FET for automatic-gain-control. The distortion is less than 0.2%.
If half the FET's drain signal is fed to the gate then the distortion is much less.
The oscillator circuit above doesn't use an opamp. It uses an LM386 power amp IC. This IC has its inputs already biased so that they work when their DC voltage is at ground. It also has negative feedback built-in. An opamp would need to have its inputs biased at half the supply voltage and have negative feedback resistors added.shirazmacuff said:I’m working on a similar oscillator using the tl071cp. I cannot seem to get it to oscillate. Can this unit be used in the circuit above, the circuit with the single supply voltage meaning + - or does it need + 0 -?
Connect three in parallel to get 9I now stuck at whereby i had constructed the circuit as as shown by audioguru for the amplifier, the only place differ is the 10ohm resistor where i replace wif 27ohm because i cant find any 10ohm around.
