Need a circuit that would switch to ground, then un-ground, then ground. This is for a automotive use to "fake" the DVD receiver to allow me to use the screen for engine management gauge displays.
So, turn car to "on"....the circuit would delay 5 seconds, then ground, then un-ground, then ground again until car's ignition is cycled off.
What I cannot figure is the delay issue on start up. The 5 second delay is important because it is a built in timing sequence used to assume the time it takes to reach to pull the E brake up and down. I can manually do this with a simple on-off switch to ground and flip it up and down whenever I drive. But that is a bit hokie.
Stu
Stu
