I dont use any governing system other than brute force loading.
I feed my wind generators back into a my home built Grid Tie inverters which are designed with a sort of exponential load rate at a certain voltage. Above a specific voltage a 2 volt increase may mean a 200% increase in power draw!
I also overbuild the generators systems by using big commercial PM DC motors so that they have considerable surge capacity well above their intended typical working range so if needed they can be short circuited at full speed in order to stall them out if the wind does get to excessive. I usually design the generator and electrical systems for a 50+ watt per square foot of swept area power capacity for continuous duty operation.
So far my only problem has been with poorly designed factory made fiberglass blades that either fly apart from bad craftsmanship or have very poor aerodynamics that limit them power wise.
Anyone with basic wood working skills and and eye for detail can make a good blade set from common wood with little more than basic wood working tools and some time. Its what I am going back to from now on.
