Hello,
For use of researching plasma and other phenomena in a high vacuum chamber, I am constructing a DC negative hot power supply that will need to supply about -40kv at 20 milliamps. My current plan is to hook a variac up to a HV transformer and then rectifying the output to negative DC voltage.
I will admit, that I am inexperienced in building and working with HV power supplies. The only real experience I have is with making gas lasers, but usually the voltages there are only about 6kv. Safety is my number one priority, and I of course, want to learn as much as I can from doing this project.
With that said, I do not just want to go out and buy some power supply, plug it in, and call it a day, but I want to actually build the power supply so I am learn from it. I was thinking of winding my own transformer (a tedious and patience requiring task yes, but one I believe will be worth it). The catch is I want it to run on 60Hz, and I do not want to deal with any capacitors or CW multipliers (for safety reasons).
I figure that in order to do this I would need an Iron transformer core that is large (to accommodate what will most likely be very large coils), and that is rated for at least 1KVA (from doing some simple math I found the transformer at least needs to be able to withstand .8KVA), and then wind the transformer primary and secondary in a ratio of 10:10,000. This way for every 1 volt in, 1,000 come out. I also assume this transformer would need to be submerged in oil, and have a vacuum put on it to prevent arcing within the coils.
What do you all think? Could it work? Is there anything I am missing or should know?
All feedback, and criticism is welcome!
