wire gauge for iPad mini 2 soldering
StealthRT
Hey all I have a simple question that I haven’t been able to find the answer to.
What gauge wire would I need to purchase in order to solder a wire to some places on an iPad mini?
The area looks like this:
h_a965cce79ab15da460df5ec13b3f1038
Originally I was thinking that 30ga would be fine but I’m not sure.
The first thing is that you probably want to use SOLDERABLE magnet wire (such as that coated with self-fluxing polyurethane insulative coat). You don't have to strip the wire before you solder it which makes it easier to solder small connections and the insulation that remains wherever your iron didn't touch prevents shorts. But take note: the fumes produced from soldering through this type of insulation are REALLY bad for you. We're not talking about regular solder fumes here. Definitely have open windows and a fan blowing. I'd try 30AWG magnet wire. It gets hard to work with anything thinner.
Why don't you pull out a metric ruler with mm and put it up against the connector and measure the pitch spacing? If it's too small, measure a few pins and divide up the measurement by that many pins. Then look up a table of wire AWG diameters.
