write string in eeprom?
i think portd.7 6 5 4... it on row... i hope true... how i can make it mask off??
Look at this option, I have checked it with your keypad settings and it works ok.
Dont forget to make Dim keyoff as Byte
lp1:
PORTD = 0x0f
keyoff = PORTD And 0xf0
If keyoff <> 0 Then
Goto lp1
Endif
it works.... tq very much...
now its going to next step;)
Thats good.;)
I would not use a code character value above 9.
Have you considered 0 thru 9 A,B,C,D,E,F [ as ASCII characters]
EDIT:
You dont need the '#' sign in front of the value when you use this method.
Also the EEPROM write is included with the LCD write routine
The value saved in EEPROM is in ASCII
Define SIMULATION_WAITMS_VALUE = 1
Define CONF_WORD = 0x3f72
Define CLOCK_FREQUENCY = 12
AllDigital
Define LCD_BITS = 4
Define LCD_DREG = PORTB
Define LCD_DBIT = 0
Define LCD_RSREG = PORTE
Define LCD_RSBIT = 0
Define LCD_RWREG = PORTE
Define LCD_RWBIT = 1
Define LCD_EREG = PORTE
Define LCD_EBIT = 2
Define LCD_READ_BUSY_FLAG = 1
'For Keypad
Symbol raw1 = RD7
Symbol raw2 = RD6
Symbol raw3 = RD5
Symbol raw4 = RD4
Symbol col1 = RD0
Symbol col2 = RD1
Symbol col3 = RD2
Symbol col4 = RD3
TRISD = 0xf0
TRISB = 0
Lcdinit
Dim button As Byte
Dim digit As Byte
Dim pass As Byte
Dim error As Bit
Dim mem As Byte
Dim keyoff As Byte
start:
Lcdcmdout LcdClear
Lcdout "ALARM SYSTEM"
Lcdcmdout LcdClear
Lcdout "New Password:"
Lcdcmdout LcdLine2Home
Lcdout "****"
mem = 0
For digit = 1 To 4  '4 digit password
Gosub get_button
pass(digit) = button
Lcdcmdout LcdLine2Pos(digit)  'replace '-' with key type
Lcdout button  ''''#button
Write mem, pass(digit)
mem = mem + 1
button = 0
Next digit
'''''''go to write input data
'''''''Gosub write_data
Lcdcmdout LcdClear
Lcdout "Password Saved"
WaitUs 2000
'Test Password
Gosub check_password
Goto start
End
check_password:
Lcdcmdout LcdClear
Lcdcmdout LcdLine1Home
Lcdout "Type Password"
Gosub get_button
Lcdout button  '''#button
button = 0
Next digit
'???? Here how to check the input password is same with saved password, error = 1 if wrong password.... some code for me?
If error = 1 Then
Lcdout "Access Denied"
WaitUs 2000
Goto check_password
Else
Lcdout "Access verified"
Endif
Return
get_button:
While button = 0
button = 0
col1 = 1
If raw1 = 1 Then button = "0"
If raw2 = 1 Then button = "4"
If raw3 = 1 Then button = "8"
If raw4 = 1 Then button = "C"
col1 = 0
col2 = 1
If raw1 = 1 Then button = "1"
If raw2 = 1 Then button = "5"
If raw3 = 1 Then button = "9"
If raw4 = 1 Then button = "D"
col2 = 0
col3 = 1
If raw1 = 1 Then button = "2"
If raw2 = 1 Then button = "6"
If raw3 = 1 Then button = "A"
If raw4 = 1 Then button = "E"
col3 = 0
col4 = 1
If raw1 = 1 Then button = "3"
If raw2 = 1 Then button = "7"
If raw3 = 1 Then button = "B"
If raw4 = 1 Then button = "F"
col4 = 0
Wend
lp1:
PORTD = 0x0f
If keyoff <> 0 Then
Goto lp1
Endif
'?????here the code wait for button release before return.... some code for me??? :)
Return
AllDigital
Define LCD_BITS = 4
Define LCD_DBIT = 0
Define LCD_EBIT = 2
'For Keypad
Symbol raw1 = RD7
Symbol raw2 = RD6
Symbol raw3 = RD5
Symbol raw4 = RD4
Symbol col1 = RD0
Symbol col2 = RD1
Symbol col3 = RD2
Symbol col4 = RD3
TRISD = 0xf0
TRISB = 0
Lcdinit
Dim button As Byte
Dim digit As Byte
Dim pass(4) As Byte
Dim error As Bit
Dim mem As Byte
Dim b As Byte
Dim keyoff As Byte
Dim readtemp(4) As Byte
start:
Lcdcmdout LcdClear
Lcdout "Press Any Key"
Gosub get_button
If button = 0 Then
Goto start
Else
button = 0
Endif
Gosub set_password
End
set_password:
Lcdcmdout LcdClear
Lcdout "----"
Gosub get_button
Lcdout button
button = 0
Next digit
Gosub write_data
Lcdcmdout LcdClear
WaitUs 2000
Return
check_password:
Lcdcmdout LcdClear
Lcdout "Type Password:"
Gosub get_button
Lcdout button
button = 0
Next digit
Gosub read_passmem
If pass(1) <> readtemp(1) Then
error = 1
Endif
If pass(2) <> readtemp(2) Then
error = 1
Endif
If pass(3) <> readtemp(3) Then
error = 1
Endif
If pass(4) <> readtemp(4) Then
error = 1
Endif
If error = 1 Then
WaitUs 2000
Goto check_password
Else
Endif
Return
write_data:
mem = 0x30  'memory address start
For digit = 1 To 4
mem = mem + 1
Next digit
Return
read_passmem:
Lcdout "----"
mem = 0x30
For digit = 1 To 4
Read mem, readtemp(digit)
Lcdout readtemp(digit)
mem = mem + 1
Next digit
Return
get_button:
While button = 0
button = 0
col1 = 1
col1 = 0
col2 = 1
col2 = 0
col3 = 1
col3 = 0
col4 = 1
col4 = 0
Wend
Gosub lp1
Return
lp1:
PORTD = 0x0f
If keyoff <> 0 Then
Goto lp1
Endif
Return
here the code... its working... if u have some suggestion for optimize my code i will appreciate...
Now i`m going to the next step making a menu
tq very much....;)
If I enter a new pwd and then use the correct pwd again, it says Accepted.
If I enter the incorrect pwd I get Denied, but after that even when I enter the correct pwd I get denied.
Also you do not want to offer the user the option to enter a new pwd every time you power up..
The program has to recognise the correct previous pwd on power up
the code is ready, now i`m going to test with circuit... need to assemble circuit.... may take a few dayssssssss... :D
