I want data from a 12v windspeed sensor that communicates with a 4-20mA signal. I chose a XY-IT0V breakout board to receive the signal. The XY-IT0V documentation (see link) describes two pots that set the bottom and top (span) output voltages to correspond with the 4-20mA input. I chose jumpers for the 0-5v range and set the bottom voltage to 0.100v at 4mA. The top voltage is set by adjusting the span pot, but cranking it up gets the top voltage to only 4.096v at 20mA. Should I live with that or is there something I can do to get the full range? Thanks for help with this.
