That arrangment will give you between 40 - 125mA. Use 100R 1 watt. Put 470u across the output.
That's what I suggested in the first place but since these small plug packs have such poor regulation, the voltage can rise as much as 3-4v between no-load and full-load and this may produce excessive voltage for the piano.It will be much more efficient (and simpler) to just use a zener diode in SERIES between the 12v power and the 7.5v output.
Oh I see it's a capacitor!The 470u is a 470 microfarad electrolytic. This will reduce some of the hum that might come from the power suplly.
It has 470/16 on the side of the body or 470/25v and has a black stripe down one side to indicate the negative lead.
I don't want that?That's what I suggested in the first place but since these small plug packs have such poor regulation, the voltage can rise as much as 3-4v between no-load and full-load and this may produce excessive voltage for the piano.
