Muttley600
Wow, was my theory that bad it didn't get a reply
Back from work now, quick cuppa then see if I can work it out
Edit: gotta ask this, so what is a waveform? Current or voltage or neither?
(here we go. Ol' CBB gonna try to s'plain how da watch works...)
Neither. and yet, both.
only their affect on objects that behave a certain way if in the presence of waves.
That's not to say that there's no energy involved, it's just not the kind of energy we think of as electricity.
Fortunately, some very wise folks came up the math that let's usl at least be able to control the stuff. How it all works, I'm quite sure, is just plain old magic.
Some clues are in the designations:
C (Capacitor) The voltage across a capacitor cannot change instantaneously.
L (Inductor) The current through an inductor cannot change instantaneously.
R Resistor The current and voltage across a resistor can change instantaneously
D Diode
Q (Some sort of semiconductor like a transistor)
we will manipulate electric in whatever outcome we desire.Yes. And ain't that neat?
So the waveform ... is basically a rate of oscillation back & forth on AC that is measured in frequency
Yes. Excellent.
I have even read the diffence between how AC & DC is converted by an alternator/dynamo
Do you know, I never realised that AC works on magnetic force rather than brushes & now understand why you get that back an forth motion of AC
A transient is basically a quick fluctuation in circuit of either voltage or current
All those scary looking sums are just a means to calculate componant values & should actually make life easier when needing to work things out.
So, am I ready for componants now, please say yes
Yes to all of the above.
So am right in thinking a capacitor smooths voltage out
an inductor smooths current out, both at a fixed value
but a resistor actually changes the value
a diode only lets current one way (generally, until you start looking at individual componants)
a semiconductor is some sort of switch to control either current or voltage
Yes. These are all true enough in a DC environment. And at the moment we're limiting our discussion to DC only.
But on that note, resistors have the same affect on DC as well as AC, but capacitors and inductors behave a lot differently in an AC environment. We can discuss that later once we work out the DC side of things.
as kiss explained, so basically capicitors & inductors are some form of regulator/safety device compared to resistors being able to alter value but they cannot restrict overvoltage/current[/QUOTE
Yes to the first part: "regulator/safety device compared to resistors", but no to the second part: "but they cannot restrict overvoltage/current". They can but again, more often in an AC environment and to a lesser extent a DC arena.
I remember that I had to figure out DC theory first before I was able to get even close to working out AC theory.
So hang in there. You'll get it.
You've done very well understanding what can be an enormously complex set of concepts, and in very short time.
You know, it's funny how things go in this world.
If people didn't break things, many of us wouldn't have anything to do.
1. so where to start, is that gold & black componant a zener diode or switching diode
2. then we have three cream things that look like resistors but don't
3. R7, is that a 252 ohm /5% tolerance resistor?
4. R2, 202 ohm /5%
5. R1, 162 ohm /20% tolerance
6. same with a big white one (so is this a 22.4K ohm/5% tolerance resistor?) R4 on the board at bottom
7. then theres two black & silver things that look like recitfiers
if those are all resistors, the more tolerance they have, the bigger they get
I think I see a N4 number on it. I would gess a 1N4XXX signal diode.so where to start, is that gold & black componant a zener diode or switching diode
Please excuse me for being late. Had a hectic day and I am (at heart) lazy. But I have begun to decipher the board for a schematic BUT, it ain't ready yet...
OK, Let's start here.
1. Yes
2. ALL of the thingys with colored stripes, flat or standing up, ([(except the black ones with a silver band) are resistors. The black/silver ones are diode/rectifiers.
3. R7 is a 2500 (2.5k) ohm resistor 1[SUP]st[/SUP] (Red=2, 2[SUP]nd[/SUP]green=5, 3[SUP]rd[/SUP]red [multiplier, 100]).
4. Probably 100 ohms (could be wrong. Hard to tell the first color) and same decode as in 3. above.
5. Hard to see, but my guess is an 1800 (1.8k) ohm.
Don't forget. First two colors are digits and the third is a multiplier:
black=1
brown=10
red=100
orange=1000
etc.
6. Looks like 2200 (2.2k) ohms with 1% tolerance.
Tolerance values are: NO 4[SUP]th[/SUP] band, 10%, Silver band, 5% and Gold band, 1%.
NOTE that the tolerance bands are separated a tad more from the first 2 or 3 bands that code the resistance value.
7. Yes.
Lastly:
The tolerance refers to the accuracy of the resistance value, i.e., how close to the rated value (by the color code) is the actual resistance likely to be. For close tolerance work, I always measure the resistor with an ohm meter first before I put it in the circuit. But, to be honest, I rarely need precision resistors. 5% or 10% is generally just fine (and cheaper).
On that note, the physical size of a resistor is a general indication of what sort of power (watts) it can dissipate (how much current it can handle before it literally burns up). Bigger size=bigger dissipation. R5 looks like 1/8 watt, while r7 looks like 1/4 watt and R4 1/2 watt.
How was this for ya?
CBB
how do you check them then, put power through one end
