16 Segment LED project help required
Identity_Crisis
I am trying to make a custom automotive component.
Instead of having the usual P,R,N,D,3,2,1 on my cars shifter console I want to have a RED LED 16 segment illuminate the shifters position.
I have worked with some electronics in the past but I am unsure how to set this up.
ON the mechanical side I will have to set up a 12V activation switching from the shifter to the electronics. This wont be that hard.
Can anyone tell me how to and what to use to wire up a single 15 Segment LED?
Thanks in advance for sharing your knowledge.
Shawn
Shawn
hi and welcome,
You could use a 16LED driver IC, see image and/or a PIC [mcu] and two 8 bit shift registers.
  • maxim.pdf
  • TPIC6595.pdf
since you have only one switch activated at a time, you can simply wire the power via diodes. example to display "3" you need 5 diodes from particular position switch to the segment to be displayed. to display "1" you need 2 diodes & so on.
A simple solution is the "diode ROM" mentioned by mbarazeen. All you need is the display and a handful of resistors and diodes.
Which type of display do you intend to use, common anode or common cathode?
