Hello everybody,
I recently purchased a portable led light which has 24 Leds in it. After opening it up, I found that all the led's are wired in parallel and no current limiting resistors are used. They are driven by 4 x 1.5v AA batterys and are reasonably bright when lit. The voltage across the cells drops from 6.4V (no load) to 3.0V (full load). I do not have any specs for the Leds.
Question:1) Are the leds wired like this to give max brightness at the expense of led and battery life? The battery's are supposed to last 30 hours (according to the specs on the box) but I cannot see this being true.
2) Does the voltage drop to 3v because this is Vf of the Led's? If so, across what is the other 3.4 volts lost?
3) I am considering using 3 maxim chips (8596x) to drive the leds with 25ma and prolong battery life. Has anybody else used these chips with good results?
Sorry about the bad pic quality
