ParkingLotLust
Starting to order parts. To those who know their parts, are these good-quality capacitors and good diodes?
0.1uF
100uF
10,000uF PSU Filter Caps
Rectifier Diodes
Power Supply:
Transformer is a 20-0-20v 220VA or higher torroid (hopefully) chosen to produce ~25v after diode drops.
Also, the image above shows two separate grounds, is it fine to connect these two together for the normal ground like in is:?
EDIT My newly-minted eagle schematics, if someone could please check 'em over
Starting on the board now.
0.1uF
100uF
Rectifier Diodes
Power Supply:
