A typical automotive alternator is a 12 pole unit so if you know you're working RPM's you can figure out the base frequency from there. At 3600 RPM you would have a 720 Hz base frequency which if its a commercial unit rated for continuous duty would be rated at 3600 RPM Vs the typical 6000+ RPM that most automotive units are.
Now as for the rest of the system and components there are some common misconceptions regarding rectifiers three phase power and general wiring.
First of any decent rectifier is rated for average amps which means that you don't need a huge amperage rating for rectifying three phase power. To be honest the diodes in your original alternator despite it being a 120 amp rated unit were likely not rated for much over 40 - 50 amps each tops. I have never found any alternators that used huge current rated diodes for their relevant amperage ratings.
Reason being for practical purposes to get 120 amps DC out of three phase AC they average current per phase would be about 34 amps which for our application a 50 amp three phase bridge would be plenty enough.
Next is realistic overhead voltage rating which for a 12 volt systems any diode with a 50 or more volt rating is way more than you need so the 1600 volt rating is just wasting power due to it inherent higher forward voltage drop which is likely around 1 volt Vs what a common germanium type diode which was commonly used due to it low forward voltage drop of ~ .3 - .4 volts at full load hence how they get so much power through a bridge rectifier with such a small heat sink even with air cooling.
So given that, by realistic and past personal experimenting with modified alternators of all makes and ages your alternator using 6 Ga wire for each phase should be able to supply a good 100+ amps at the 12 - 15 volt range it's rated to work at a good 50+ feet away! Odds are if it was a quality commercial unit that has a fair amount of reserve capacity that could be used to compensate for a bit of voltage drop in the lines even 10 ga wire for a 50 foot run would be more than big enough.![]()
Thanks tcm. This is a continuous hd alternator not a standard car alternator albeit it is still a small not large case alt. It has a 3 pairs 50A diodes each internal bridge. As you can see I did a frequency calc above but with half the result of yours so I might have made a mistake, noting my RPM's are rotor, not engine, whereas yours might have been gas engine revs with a 2:1 pulley ratio allowed?
The run lengths contemplated between alternator and remote rectifier will either be around 3' or 6' so that does not appear to be an issue.
I haven't mentioned it here for simplicity but I do have a second 250A 16 pole large case remote regulated alt which on numbers above still has a frequency <1 KHz so I assume skin effect not an issue. For redundancy and spare parts reasons I would like to use an identical remote rectifier for both which is why I settled on a 300A bridge rectifier.
However your comment that it's 1600v rating is just wasting power concerns me. Should I be looking for say a 50v spec, if indeed such a thing is available?
Thanks in anticipation.
