Veraxis
Active Member
Was also looking at these **broken link removed** it offers many advantages, you can view the preset voltage, input voltage, output voltage, the preset current, output current, output power, etc. on the output state remind area, you can see that output opens or not, the state of constant voltage and constant current, output is normal or not, the key is locked or not, and the current data groups that is being used. On the setting data interface, you can adjust overvoltage value, overcurrent value, over-power value, data set and LCD brightness. And it's really well calibrated from the factory. Well worth the money.
My only dilemma is that it comes with a step down module and it needs an ac to dc supply to power it. So as it has Input Voltage listed at DC6-40V. Was thinking of getting a dc power supply that would allow me to use it with this contraption.
So I was looking at these **broken link removed** but it's not a linear one it's a switch. So waiting for more great advice. Thanks in advance.
You could do that if you wanted, but it would require a bit more work on your part. I guess I don't know if those modules would be good or not. I'm guessing that you would want to assemble it all into some kind of case so that you don't have live mains wiring out in the open. It's certainly got a nice display, but it wouldn't be as much of a plug-and-play solution.
Also, where do they specify the accuracy of the calibration? I see the resolution ratings for the display, but that doesn't necessarily mean that it will be accurate to 0.01V. It might say 5.00V on the display, but actually be anywhere from 4.75-5.25V in reality if it had, say, a +/- 5% accuracy on the voltage. The current even more so, as it appears to be using fairly generic wire shunts to measure the current, which usually need to be "calibrated" a bit with notches or solder blobs to dial in the resistance to more than about +/- 10%. They could also be using a software calibration, but it's important to make the distinction between precision and accuracy.
I'm also not sure how comfortable I would be with running 12A through those dinky little wire terminals on the two lower current versions. If you were making this into a more permanent bench supply, I might unsolder the terminals and solder some fairly thick wires directly into the board.
The second set of supplies listed are fairly generic switching power supplies. I have used ones like these before, and the quality of these is reasonable aside from the occasional reports of units with bad solder joints or power transistors improperly clamped to the heatsinks. The listing for the DC-DC converter seems to suggest that it is more efficient in the buck mode when it says that "Please ensure that the input voltage is higher than output voltage above 1.1 times," so I would probably recommend going for the 36V version if you decide to go this route (out of stock on that listing, but probably available elsewhere on eBay).
If you have an oscilloscope with one-shot storage, I would also want to carefully characterize it's turn-on, voltage switching, and steady-state behavior for overshoot transients, rise time, and ripple, which are important characteristics in a power supply if you intend to use this for more than just basic short testing. You will probably want to look at these behaviors both for an open-circuit and under load. If you have a non-storage analog scope, you should at least still measure the ripple. You will also want to keep a close eye on the temperatures to make sure those heatsinks aren't getting too hot under load.
