3x3x3 LED Cube - can i use16f628 instead 16f690
I am using the circuit and the asm code as on below. Do you think that could there be a problem on the asm code?
led-asm.25880
  • LED.asm
	bsf		STATUS,RP1			; select Page 2,
	bcf		STATUS,RP0			; by setting RP1 in Status register and clearing RP0
;	clrf	ANSEL				; select Digital I/O on port C
;	clrf	ANSELH				; "		"
    bcf		STATUS,RP1			; back to Register Page 0
The PIC16f628a does not have any ANSEL registers look at the datasheet
So this code will not compile.
Make sure you go back into bank0 after clearing the Tris registers
i use not 16f628a, i use 16f628..i completed my circuits..but leds are blinking complicated..i hope, my asm code is wrong für my connection..could u send me circuit schema and asm code?
what does it mean "a,,? soryy because that.i'm working hard but i didn't find problem..The leds are blinking absurd..am i connecting my pic's ports wrong? is that so?
thanks...
