yes ..so i avoid those in the simulation model as posted #18.Why don't you use a bus??
To avoid simulation speed dropping below real time... Do not use resistors and transistors.. There is no need to sim the 5v regulator either..
RA4 -- Output is open-drain type.Questions:
Q7 has no emitter resistor. It is not wired like the other transistors. Why?
What current are you expecting to go through the LEDs? With a 5k emitter resistor then the LED current is vary low!
Why R4?
How much current in D2, D4?
yes indeed. im not expert in that.Oh my, what a mess!![]()
