A/D On 18F1320
I've moved a couple things around and added OSCCON
    list p=18F1320
    include <p18F1320.inc>
    CONFIG OSC = INTIO2, WDT = OFF, LVP = OFF
    cblock    0x00
    Count
    advtemp
    L2T
    endc
    org 0x00            ; reset vector
LED    macro    x,y             ;MACRO LED <PORTA>, <TRISA>
    movlw    x
    movwf    LATA        ;LATA = x
    movlw    y
    movwf    TRISA        ;TRISA = y
    call    Delay        ;call the Delay subroutine
    endm                ;end macro
    goto Main
    org 0x08            ;  ISR Low vector
    goto ISR
    org 0x18            ;  ISR Low vector
    goto ISR
Main      movlw     0x72         ; 8MHz clock select
      movwf     OSCCON
    CLRF    PORTB        ;Initialize PORTB by clearing output data latches
    CLRF    LATB        ;Alternate method to clear output data latches
    MOVLW    0x01        ;A/D Config
    MOVWF    ADCON1        ;ADCON1: All analog except AN0
    MOVLW    b'00000010' ;TRISB Config
    MOVWF    TRISB        ;Set RB1 as input RB<7:2> and RB0 as outputs
    MOVLW    b'11001000' ;INTCON Config
    MOVWF    INTCON        ;Enable GIE/GIEH, PEIE/GIEL, RBIE Disable rest
    MOVLW   b'11110101' ;INTCON2 Config
    MOVWF    INTCON2        ;Enable RBPU, Rising Edge Interrupts, High Priority
    MOVLW    b'11001000' ;INTCON3 Config
    MOVWF    INTCON3        ;High Priority, Enable INT1 and Clear Flags
    movlw    b'00010101'    ;enable A/D, AN5
    movwf    ADCON0
StartUp     bsf    ADCON0,GO    ;Start A/D conversion
adloop    btfsc    ADCON0,DONE ;Check if done. If not goto adloop else skip loop
    goto    adloop
    MOVLW    0xEE             ;Button Pressed Preset
    CPFSLT    ADRESH            ;If ADRESH < Skip the goto else start over
    goto    StartUp            ;because no button pressed
Check1    MOVLW    0xBF        ;4th button Preset
    CPFSGT    ADRESH            ;If ADRESH > BFH then this button was pressed
    goto Check2                ;If not then it wasnt pressed skip to next check
    MOVLW    0x04
    MOVWF    L2T                ;Set L2T to 0x04 (MY LOOP COUNTER)
    goto LEDXT                ;Goto LEDXT which is the Light X Times where x = 4h for this button
Check2    MOVLW    0x7F        ;3rd button preset
    CPFSGT    ADRESH            ;If ADRESH > 7FH then this button was pressed
    goto Check3                ;If not then it wasnt pressed skip to next check
    MOVLW    0x03
    MOVWF    L2T                ;Set L2T to 0x03 (MY LOOP COUNTER)
    goto LEDXT                ;Goto LEDXT which is the Light X Times where x = 3h for th
Check3    MOVLW    0x3F        ;Same as others
    CPFSGT    ADRESH
    goto Check4
    MOVLW    0x02
    MOVWF    L2T
    goto LEDXT
Check4    MOVLW    0x00        ;Same
    CPFSEQ    ADRESH            ;If ADRESH = 0 then goto LED1T because button 1 was hit
    goto StartUp            ;if not then goto startup
    goto LED1T                ;LED 1 Time
LED1T
    call ScrollMe            ;Scroll LEDs 1 time
    goto StartUp            ;Goto Startup
LEDXT                         ;LEDXT loop
    call ScrollMe            ;Scroll 1 time
    DECFSZ    L2T                ;Decrement L2T and skip the next line if 0
    goto    LEDXT            ;goto ledxt loop
    goto    StartUp            ;Goto StartUp
Delay    decfsz    Count,f    ;decrement Count and skip when zero
    goto    $-2             ;not zero? repeat
    return
ScrollMe
    LED    b'00000001',b'10111110'    ; Light LED 1
    LED    b'01000000',b'10111110'    ; Light LED 2
    LED    b'01000000',b'00111111'    ; Light LED 3
    LED    b'10000000',b'00111111'    ; Light LED 4
    LED    b'10000000',b'01111110'    ; Light LED 5
    LED    b'00000001',b'01111110'    ; Light LED 6
    return                         ; Return from where called
ISR    BCF INTCON3, 0                 ; Clear INT1
    BCF INTCON, 0                ; Clear RBIF: RB Port Change Interrupt Flag bit
    call    Delay                ; 2 delays
    call    Delay
    retfie                        ; Return from where called
    END
Dude i cant seem to get the delay right. I used the Delay Code Generator to make the below and it doesnt work or maybe im doing something wrong?
; Delay = 0.2 seconds
; Clock frequency = 8 MHz
; Actual delay = 0.2 seconds = 400000 cycles
; Error = 0 %
	cblock
	d1
	d2
	d3
	endc
Delay
			;399992 cycles
	movlw	0x35
	movwf	d1
	movlw	0xE0
	movwf	d2
	movlw	0x01
	movwf	d3
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay_0
			;4 cycles
	goto	$+1
	goto	$+1
			;4 cycles (including call)
	return
; Generated by http://www.piclist.com/cgi-bin/delay.exe (December 7, 2005 version)
; Fri Mar 14 23:43:27 2008 GMT
; See also various delay routines at http://www.piclist.com/techref/microchip/delays.htm
My code would be:
    list p=18F1320
    cblock    0x00
    Count
    advtemp
    L2T
	d1
	d2
	d3
    endc
    movlw    x
    movlw    y
    endm                ;end macro
    goto Main
    goto ISR
    goto ISR
Main
    movwf    OSCCON
    movwf    ADCON0
    goto    adloop
    MOVLW    0x04
    MOVLW    0x03
    CPFSGT    ADRESH
    goto Check4
    MOVLW    0x02
    MOVWF    L2T
    goto LEDXT
LED1T
LEDXT                         ;LEDXT loop
;Delay
	;decfsz    Count,f    ;decrement Count and skip when zero
    ;goto    $-2             ;not zero? repeat
    ;return
Delay
			;399992 cycles
	movlw	0x35
	movwf	d1
	movlw	0xE0
	movwf	d2
	movlw	0x01
	movwf	d3
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay_0
			;4 cycles
	goto	$+1
	goto	$+1
	return
ScrollMe
    call    Delay
    END
But not working
On the bright side this is my final 4 button pad design. Since its for testing on various projects i will not doll it up with a case and such.
I made the connector from some old parts off an old motherboard i had around.
And no wonder. You can't use "goto $+2" on an 18F. You must change those to "goto $+6". The delay calculator was made for 16F's. So of course your delays are completely screwed up. :D
Like this:
Delay	movlw	0x23			;2 second delay @8MHz
	movwf	d1
	movlw	0xb9
	movwf	d2
	movlw	0x09
	movwf	d3
Delay_0	decfsz	d1,F
	goto	$+6
	decfsz	d2,F
	goto	$+6
	decfsz	d3,F
	goto	Delay_0
	return
Ya, unless I need precision I always strip the excess clutter (those little fine-tuning goto's and nops) out of delays made by the piclist generator. Even if I do need precision I still clean it up. The comments are splattered all over the place and the labels are on the line before the code. They can almost always be on same line as code (depends on length of label).
Ok got it at 100ms heres the delay:
Delay
			;199993 cycles
	movlw	0x3E
	movwf	d1
	movlw	0x9D
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+6
	decfsz	d2, f
	goto	Delay_0
			;3 cycles
	goto	$+2
	nop
	return
Thanks a bunch i didnt know that :D
Delay
			;199993 cycles
	movlw	0x3E
	movwf	d1
	movlw	0x9D
	movwf	d2
Delay_0	decfsz	d1, f
	goto	$+6
	decfsz	d2, f
	goto	Delay_0
			;3 cycles
	goto	$+2
	nop
	return
Ya, but clean up the delay like this:
Delay	movlw	0x3E		;100ms
	movwf	d1
	movlw	0x9D
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+6
	decfsz	d2, f
	goto	Delay_0
	goto	$+2		;can be deleted if you don't need precision
	nop			;can be deleted if you don't need precision
	return
The generator builds nasty, cluttered looking code.
AtomSoft said:
1 silly question
will comments be in code? Like do they take up space? if not can i just comment out the code?
Comments take no space in the PIC. They are ignored by the assembler. If you want code left in your source for later use but not assembled then by all means just comment it out. Standard practice.
Thanks Then The Final Code Is:
    list p=18F1320
    cblock    0x00
    Count
    advtemp
    L2T
	d1
	d2
	d3
    endc
    movlw    x
    movlw    y
    endm                ;end macro
    ;goto Main
    ;org 0x08            ;  ISR Low vector
    ;goto ISR
    ;org 0x18            ;  ISR Low vector
    ;goto ISR
Main
    movwf    OSCCON
    movwf    ADCON0
    goto    adloop
    MOVLW    0x04
    MOVLW    0x03
    CPFSGT    ADRESH
    goto Check4
    MOVLW    0x02
    MOVWF    L2T
    goto LEDXT
LED1T
LEDXT                         ;LEDXT loop
;Delay
    ;return
Delay
	movlw	0x3E
	movwf	d1
	movlw	0x9D
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+6
	decfsz	d2, f
	goto	Delay_0
	goto	$+2
	nop
	return
ScrollMe
;ISR    BCF INTCON3, 0                 ; Clear INT1
    ;BCF INTCON, 0                ; Clear RBIF: RB Port Change Interrupt Flag bit
    ;LED    b'00000001',b'01111110' ; Light LED 6
    ;call    Delay                ; 2 delays
    ;call    Delay
    ;retfie                        ; Return from where called
    END
blueroomelectronics said:
Instead of goto (long branch) try using bra +4 instead of goto +6
what would be the difference?... just asking because i never really understood why use bra instead of goto whats the advantage?
I haven't looked this up, but if the 1320 is anything like other CPUs I've worked with there are short jumps and long jumps. Short jumps (bra) are quicker and/or smaller but have limited range. A short jump typically jumps 8-bit relative to the PC. Long jumps (goto) can jump anywhere in memory (absolute - not relative to the PC) but are a bit slower and/or take more space. They're typically a 16-bit absolute jump (maybe 12 or 14 bits on PICs - PICs are weird :D ).
EDIT: Looked it up and I'm correct except in the details. Bra is a 10 bit PC relative jump and is 1 word long. Goto is a 20 bit absolute jump and is 2 words long. Both take 2 cycles.
ok FINAL code lol
    list p=18F1320
    cblock    0x00
    Count
    advtemp
    L2T
	d1
	d2
	d3
    endc
    movlw    x
    movlw    y
    endm                ;end macro
    ;goto Main
    ;goto ISR
    ;goto ISR
Main
    movwf    OSCCON
    movwf    ADCON0
    goto    adloop
    MOVLW    0x04
    MOVLW    0x03
    CPFSGT    ADRESH
    goto Check4
    MOVLW    0x02
    MOVWF    L2T
    goto LEDXT
LED1T
LEDXT                         ;LEDXT loop
;Delay
    ;return
Delay
	movlw	0x3E
	movwf	d1
	movlw	0x9D
	movwf	d2
[b]Delay_0
	decfsz	d1, f
	bra		$+4
	decfsz	d2, f
	;goto	Delay_0
	bra		$-6
	bra		$+2
	nop
	return[/b]
ScrollMe
    ;call    Delay
    END
AtomSoft said:
ok FINAL code lol
Main
    movwf    OSCCON
I just realized why your code always looks like a messed up jumble when you post it. The fix is to change your tab size in MPLAB to match the 8 space tabs used by this web-site. Go to Edit/Properties and an Editor Options window will open. Switch to the 'ASM' File Types tab and change tab size from 4 to 8. Leave Keep tabs selected. Hit OK.
Now all your source code will be tabbed wrong. Every time you edit an existing source file, clean up all the excess tabs. There will be too many. On new files you'll use a single tab where you were using two.
And best of all, when you post here your code will look great instead of hideous! :D Good looking code gets you more and better help. It's hard enough reading through unfamiliar code without it being sloppy looking because the site's Code tags moved everything around.
Lets see if this is better:
	list p=18F1320
    	cblock    0x00
    	Count
    	advtemp
    	L2T
	d1
	d2
	d3
    	endc
	movlw    x
    	movlw    y
    	endm                	;end macro
    	;goto Main
	;org 0x08           	;  ISR High vector
	;goto ISR
    	;goto ISR
Main
    	movwf    OSCCON
    	movwf    ADCON0
    	goto    adloop
    	MOVLW   0x04
    	MOVLW   0x03
    	CPFSGT  ADRESH
    	goto 	Check4
    	MOVLW   0x02
    	MOVWF   L2T
    	goto 	LEDXT
LED1T
LEDXT                         	;LEDXT loop
;Delay
    	;return
Delay
	movlw	0x3E
	movwf	d1
	movlw	0x9D
	movwf	d2
Delay_0
	decfsz	d1, f
	bra	$+4
	decfsz	d2, f
	;goto	Delay_0
	bra	$-6
	bra	$+2
	nop
	return
ScrollMe
    	;call    Delay
    	END
