I don't see any change in distortion at those frequencies, at least not from 50Hz to 60Hz. A 60Hz transformer running at 50Hz could cause some if the transformer starts to saturate at the lower frequency.dknguyen said:I think with a 50Hz transformer running on 60Hz, there will be more distortion. I don't know about getting hotter, but I don't think distortion necessarily means it gets hotter (and it probably doesn't matter since it's a power transformer).
I'm applying what I know about audio transformers to these transformers. BUt yeah, the frequencies are so close and they are a power application, not signal, so it's probably negligble.crutschow said:I don't see any change in distortion at those frequencies, at least not from 50Hz to 60Hz. A 60Hz transformer running at 50Hz could cause some if the transformer starts to saturate at the lower frequency.
Diver300 said:For higher frequency transformers, less iron is needed, but the laminations should be thinner..
rjvh said:can sombody explane this than i know that the higher the frequency the smaller the transformer
what does the thickness of the laminations to do with it
other thing is if i look the transformers in a swiched power supply (computer) the transformer core is ferrite
what are tyhe benefits of ferrite above iron cores at this aplication???
Robert-Jan
At the high frequencies of switching power supplies even thin laminations have too high eddy current loss. Ferrites are used since the material has a much higher electrical resistance than iron which keeps the eddy currents (and power loss) low.rjvh said:what does the thickness of the laminations to do with it
In general, thinner laminations will have less eddy current loss.
