Because a remote control uses a specific device code, a TV one uses a TV device code and an AirCon one uses an AirCon device code - so unless something was incredibly badly designed they couldn't ever work each other.
It wouldn't be a TV remote in that case, and a 'programmable' one wouldn't be able to do an AirCon unit - unless it was specifically designed to do so, which seems unlikely. As for 'learning' remotes (rather than programmable) it's quite likely a learning remote could be used to record from an AirCon one, but it still wouldn't be a TV remote as it wouldn't work a TV.
It 'could' be, but it wouldn't be - it would be pretty stupid building an AirCon unit that turns OFF every time you turn the TV volume up![]()
Hi Nigel,
Well then you might want to explain why when we turn the TV volume up the VCR, SetTopBox, DVR Player, Audio Amp/Receiver, all dont turn off, is it magic or what
Correct me if i am wrong, but it sounds like what you are saying is that the remotes we can presently get on the market NOW do not do both entertainment stuff AND air conditioners. That is, right now, today. But how about tomorrow? Will there be a remote able to do this, and why not? I for one do not see a good reason why they should not do both. "Device" codes allow us to choose what device we turn on and off, while the other buttons just control what happens to that device such as volume or channel.
Could it be that there are no device codes left for new stuff like AC units? I would think adding another digit to the device code would give us another set of 1000 or so.
What hyedenny seems to be suggesting is that it is very possible and actually would be easy to have a remote control that could do both types of devices, especially since the codes are similar in at least some units. I guess it could be that the codes for SOME AC units are so unique that it cant be done for those models very easily, but then again it's just pulses of light.
