In a sealed system I.E. Refrigeration if you have the presents of water the mineral oil develops acids.
kv
Where did you get that idea? Water is not an oxidizer. Pure mineral oil does not react with it at any discernible rate.
John
kv
John
Therefore organic acids are rarely if ever found in today’s air conditioning systems in any
appreciable concentration.
Both inorganic and organic acids are corrosive. However, inorganic acids have a higher
dissociation constant making them strong and very reactive acids, while organic acids react
much slower. In the case of mineral oils, elevated temperature causes the oil to ultimately break
down and the ultimate products are carbon and hydrogen gas. Only in the presence of an
oxidizer, such as oxygen or air, can organic acids be formed. In the case of synthetic POE oils,
organic acid may be initially present (up to 8 PPM) as a residual from the esterification
manufacturing process used to make the ester oil. It is therefore clear that the real acid problem
in refrigeration/air conditioning systems is an inorganic acid problem not an organic acid.
Take note though, unleaded does not have a rusting effect on silencers.
And off coarse, the water is not pure either, mixed with methanol. Pilots always talk about water meth injection.
Exhaust systems on cars with catalytic converters run hoter. But if trips are short they never get up to temp.
Do you think UK's comparatively wet climate to our dry climate can be a factor Nigel?
Oh, and none of my vehicles use cats, and I probably never will make use of a cat system.
I've also been lucky with batteries, seem to get quite a lot of years from them, 5+ years with my Ikon before failing.
I've heard people talking that unleaded fumes are very toxic, but it could be nasty rumours.
We've had reports of poor reliability and tremendous expense with cats so I stay clear. It's almost the very expensive and luxury vehicles here that is fitted standard with cats.
So does cats reduce the amount of CO2 emissions?
We don't have leaded fuel any more, haven't had for some years now.
We do have these so called dual fuels, or lead substitute fuels, since we still have quite a number of vehicles from the leaded era on our roads.
I would think that we are far from that law over here, maybe by that time some alternative that all manufacturers are claiming to be close will be with us already.
So my conclusion is that the IC engines are not as efficient in its combustion as they claim.
I don't think anyone has ever claimed any great degree of efficiency for IC engines? - nor does it's specific waste products have any real bearing on it's efficiency, you could probably increase efficiency at the cost of making it's waste products worse.
