animator303
I would GREATLY appreciate any help or guidance for this project.
The basic idea behind this is to have 3 bases that can be captured, one at a time, and randomly chosen.
I have written out the logic of this system. It looks like some sort of programming language but Im sure it can be translated onto a PCB of some kind.
I am hoping to use two way radios as the communication devices between the stations like **broken link removed**
STATION 1: START
IF signal received
then choose random number (1,2,3)
IF 1 then activate capture process on STATION 1
IF 2 then send signal to STATION 2 (using two way radio)
IF 3 then send signal to STATION 3 (using second set of two way radio)
STATION 1 CAPTURE PROCESS:
IF 1
then CAPTURE PROCESS START
then LIGHT SETTING 1 (blink)
IF EXECUTE OFF (meaning no one has captured it yet)
then standby
IF EXECUTE ON (meaning someone has HIT the execute button)
then LIGHT SETTING 2 (solid)
then AUDIO signal ON
then 'countdowntimer' START
IF 'countdowntimer' = 0
then LIGHT SETTING 0 (off)
then AUDIO signal OFF
then add score to current TEAM
CAPTURE PROCESS END/
STATION 2 AND 3 CAPTURE PROCESS:
IF receive signal
IF EXECUTE OFF
then standby
IF EXECUTE ON
then send signal to STATION 1
If anyone knows of ready made components that can be used for ANY part of this I would be forever in your debt!
Cheers
-Mike
STATION 1: START
IF signal received
IF 1
then standby
IF receive signal
IF EXECUTE OFF
then standby
IF EXECUTE ON
Cheers
-Mike
