throbscottle
I thought it was just my eyes there - I also read them as 2.7M 10% - though I didn't notice the apparent blue band.
For some reason on my monitor all the resistors look like: Red, violet, green, silver, blue. You do the math. That's all three that look the same. The red band is much wider than the violet band and the other bands.
Solution:
Take more pictures from various different angles and post here. One picture is not always good enough for 3d items or for resolving colors. Pic's these days are cheap, almost nothing to take one and see it on the monitor, so take more, more more![]()
Before DEFLATE is applied, the data is precompressed, via a prediction method: a single filter method is used for the entire image, while for each image line, a filter type is chosen that transforms the data so that it is hopefully more easily compressed.[13]
There is only one filter method in the current PNG specification (denoted method 0), and thus in practice the only choice is which filter type to apply to each line. For this method, the filter predicts the value of each pixel based on the values of previous neighboring pixels, and subtracts the predicted color of the pixel from the actual value, as in DPCM. An image line filtered in this way is often more compressible than the raw image line would be, especially if it is similar to the line above, since the differences from prediction will generally be clustered around 0, rather than spread over all possible image values. This is particularly important in relating separate rows, since DEFLATE has no understanding that an image is a 2D entity, and instead just sees the image data as a stream of bytes.
There are five filter types for filter method 0; each type predicts the value of each byte (of the image data before filtering) based on the corresponding byte of the pixel to the left (A), above (B), above and to the left (C) or some combination thereof, and encodes the difference between the predicted value and the actual value. Filters are applied to byte values, not pixels; pixel values may be one or two bytes, or several values per byte, but never cross byte boundaries. The filter types are:[14]
Type byte Filter name Predicted value
0 None Zero (so that the raw byte value passes through unaltered)
1 Sub Byte A (to the left)
2 Up Byte B (above)
3 Average Mean of bytes A and B, rounded down
4 Paeth A, B, or C, whichever is closest to p = A + B − C
Many Oriental resistors have color bands painted wobbly and with various widths by hand.
When everyone's so drunk they make perfect sense to each other...![]()
