I have a cheap x-10 home security system that uses keychain remotes to arm and disarm it. I would like to be able to use a numeric keypad to arm and disarm the system. X-10 thinks it is a stupid idea so they don't make one. I have a little experience with electronics repair on pcb's so I know what I want is possible and relatively "easy" to make. I should be able to make/buy a keypad controller. I think I can use one of the remotes inside the keypad. What I picture is a controller that after typing in a certain code you could hit enter/disarm and it would trip a relay that would connect the circuit on the keychain remote and the remote would function. The easy part would be making a circuit that would activate a relay to make the remote function. The part I would have the most trouble with is making the keypad work with a code. Can anyone lead me in the right direction? It would be great if someone made a programmable keypad that had outputs that I could tie to the remote but I doubt I am that lucky.
