Folks anyone who can assist with specs for the Pink Atom module. This module is used for small 2-stroke engines on mopeds and dirt-bikes. Pretty difficult to find.
I wonder if there is any module that replaces the pink ATOM module used for VeloSolex mopeds? The problem is that the flywheel has 4 magnets that make it all! IF there is so please a web address etc so I find it! Is not so at home in all product numbers etc and recognizes without wrapping it with, then you know what I need.
I have an old yamaha outboard from 1980 with fixed ignition timing and one cylinder. I think I need the purple module. Do you know the values? Or can I use the Red module for this?
I tested the red module. The engine starts perfectly but when I accelerate the engine stops. I also tested the brown and pink module. I do not get a spark with that. Not even if I change the polarity. the nova ii module works perfectly. I do not know what's wrong
If you purchased Chinese 2SD1071 transistors then theres a good chance they are faulty. I purchased a batch that looked genuine but had poor gain. You could use BU931 transistors from a reliable supplier, as they work.
debe the work you have done on thes modules has been incredible as well as the willingness to help others. I haven;t built your modules, but "Damn your good!"
Does anyone know of a common (Fairchild, National, IR) replacement for this component: [url]http://www.diyautotune.com/tech_articles/using_bosch_bip373s_with_me
Hi , I'm in process of building a pair of these for my '78 Volvo penta VP140 (14hp 200cc twin cylinder with adjustable ignition).
I have readily available 1.5KE220A which has 4.6 peak amperage (200A has 5.5Amp)
Other is 1.5KE200CA which is bidirectional and 4 times the price of the other .
Can a lower amperage unit survive or use bidirectional with adequate rating ?
