Odysseas
Hello there,
I have had some problems with audible popping coming from a relay in my self-brewn amplifier. Sometimes, when the relay opened, there would be a pop in the speakers (I am not sure, which one of the speakers, it was not clearly discernable), and a small, visible spark between the contacts at the end of the reeds inside the relay.
I have googled for this a bit, and apparently this problem could be solved by disengaging the input signal for the amplifiers a few milliseconds before the relay opens. However, I do not see how this can be accomplished without an elaborate DSP.
Would it help if I turned off the power for the internal preamps? I suppose this would simply cause the pop to originate from somewhere else, is that correct?
To kill off popping from power switches, there are small ceramic capacitors found across the switches - would this work here, too?
Can anyone help me with disengaging the input signal, or come up with another solution to get rid of this relay popping?
Thanks for any help!!
